Collaborate forum
IfcBuildingStorey ....Name vs LongName
Mats_Knutsson
We are testing a new ifc-app and it shows all my stories as one bottom level (no stories). First I thought this was because this app is looking for IfcLongName while I had the name of the storey in IfcName. So I've added the name of the storey to both IfcName and IfcLongName but it still doesn't work. Are there any other places I can look at? When I open the IFC in a text editor I see all positions without a value gets a $.
/M
AC 25 SWE Full
2 REPLIES 2
How does the IFC work in Solibri? Does it display the information correctly, or they way you want it?
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
It's apparently OK to use Name as a number. From: https://standards.buildingsmart.org/IFC/RELEASE/IFC4/FINAL/HTML/schema/ifcproductextension/lexical/i...
The following guidelines should apply for using the Name, Description, LongName and ObjectType attributes.
  • Name holds the unique name (or space number) from the plan.
  • Description holds any additional information field the user may have specified, there are no further recommendations.
  • LongName holds the full name of the space, it is often used in addition to the Name, if a number is assigned to the room, then the descriptive name is exchanged as LongName.
AC 25 SWE Full
Labels
