Collaborate forum
IfcDoor and IfcWindow parts
stefan
With IFC export, the translator provides the option to split elements into parts.
I'm trying to export a door with its parts, but it remains a single object upon export.
Does this setting also require a specific setup of the GDL code to distinguish between the different parts?
--- stefan boeykens --- architect-engineer-musician ---
ARCHICAD25/Revit2022/Rhino7/Unity2021/Solibri
MBP2019:i9Octo2.4GHz32GBVega20/BigSur+Win11
ARCHICAD-user since 1998
It says it in the Dialog: this setting applies only to elements using Composite Structures or Complex Profiles. So it only works on Walls, Slabs, Roofs, Shells, Columns and Beams.
https://helpcenter.graphisoft.com/user-guide/89325/#XREF_62919_Split_Complex
Of course we can ask the question of why is the IFC tree strcuture there if it does not apply to many IFC Element types. My guess is that theoretically, you could model a Window using a Segmented Column using Complex Profiles, and then you could classify it as a Window, for example, and then the IfcWindow Element Type to be broken down into Parts upon IFC Export.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
agroni
Hi Stephan,
that would be a good example. But as Laszlo is stating, this is sadly not allowed for windows and doors.
I also tried this with a windows modelled including a sun shading. The problem with the splitting is, where do you define the sub classification or entity for the splitt element. So maybe like with Stairs and Railings, a window needs a sub classification if such elements are used. Currently a window might have a shading (IfcShadingDevice) or a Beam above it (IfcBeam) in the window element itself...
Its like the the IfcBuildingElement (which is ex. a complex wall), when split becomes an IfcBuildingElementPart.
The BIMster @ AllesWirdGut
Currently: Archicad 24 & 22
User since Archicad 6.5 (2001)
