2005-02-23 03:37 PM
2005-02-23 07:40 PM
PotentialTech wrote:No: ArchiCAD stores all information internally in metric. All presentation and input in Imperial is the result of conversions. ODBC and SQL provide you with the raw internal data ... hence metric.
Is there a way to get results from Sql and/or ODBC to return in Imperial units instead of metric. The plan is drawn in Imperial units. A.K.A. I want feet, not meters.
I know how to use a formula for conversion, but I was hoping that there was a feature that I have overlooked that will do it for me. This would save me some time and eliminate lots of chances for human error.
2005-02-24 07:27 AM
.. the conversion function is written one time and is used in your queries and reports
2005-02-24 07:55 AM
PotentialTech wrote:Such is the nature of programming ... and why good programmers who examine all ramifications in order to produce robust code are not cheap.
Yes, but there will be many places that the conversion will need to be called, and if applied at the wrong time or missed, it could cause errors which are easily overlooked until a large calculation results in an ugly mistake.
I am embarrassed that I live in a country using such a backward and outdated system, even though the rest of the world has been using metric for 30 years or more.I so agree.
