Import Terrain from Rhino
Is there a tutorial on how I can import terrain from Rhino?
I have the 3d contours of the terrain in Rhino, but I find no way to import it to get the same 3d contours in ArchiCAD to be able to edit like ArchiCAD terrain.
Any pointers?;)
1 REPLY 1
Podolsky
Ace
You cannot import from any program 3D model that would automatically convert into ArchiCAD mesh tool and would let you to edit it. It only will be fixed geometry (as library part or morph).
The only way, how to convert Rhino terrain into ArchiCAD mesh - is to use Grasshopper connection and create algorithm there, that will convert Rhino geometry into editable ArchiCAD mesh.
Learn and get certified!
