Import Vectorworks Landmark Plant Library
Scott Bulmer
Greetings. I believe Archicad and Vectorworks are related software. Is there any way to obtain and load Vectorworks Landmark default plant library? Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
4 REPLIES 4
The only relation is that both companies belong to the Nemetschek Group. But there is further relation than that.
You best bet would probably be to save those plants you need from Vectorworks as DWG or IFC or some other format that ARCHICAD can read. But I don't think you will just be able to load a Vectorworks library (which is normally stored in a Vectorworks project file) into ARCHICAD.
Scott Bulmer
Thank you Laszlo - is there any add-on or library that you know of or could recommend to make Archicad more useful in landscape architecture? Vectorworks Landmark is a good example of landscape architecture software. Scott
Unfortunately I cannot recommend much.
I only went to bimcomponents.com and here is what I found:
https://bimcomponents.com/LCF/Details/817
https://bimcomponents.com/LCF/Details/3002
Erika Epstein
Scott,
Take a look at this post.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Learn and get certified!
