Collaborate forum
Importing HEIC Images
Kaihaku
Any thoughts on importing HEIC (apple/ iphone images) to ArchiCAD on windows systems?
Kaihaku
Windows 10
5 REPLIES 5
Steve Jepson
https://imazing.com/heic
This is a High Efficiency Image Container (HEIC) sample file to test the converter with if any one needs it. Or Microsoft Photos will open a HEIC file and then you save is as .JPG ArchiCAD only imports image files (5) types. HEIC is not one of them - yet.
ArchiCAD 25 4013 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2
This issue is not relevant to me but I tried to open this HEIC image in Microsoft Photos in Windows 10, and it tells me "We can't open this file".
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Steve Jepson
It works for me. Also some of my photo editing software a automatically convert that file type when opened and it is just a matter of drag and drop to the ArchiCAD screen.
This is what the sample file looks like as a jpeg
Kaihaku
Just to add to the discussion.
For Windows 10, I purchased a Codec called "View HEVC Video Extension" to allow Windows 10 to view HEIC images.
Also, I found out that I could adjust the settings in my iPhone to store images as jpg, instead of HEIC. Back to my normal.
Thanks!
Kaihaku
Windows 10
Sargent
Hi Kaihaku, do you mean to change the file format before importing it in Archicad? If you are looking to convert the file I recommend using a online converter for faster process. The one I use is Convert HEIC to PNG. You can do it with some of windows programs but this is just way more simple. I am working on some serious projects myself and still use this method. Cheers! Hope this helps.
