Collaborate forum
Incorrect calculated area of Zone Schedule
I set the Zone deduction(Figure 01), column relatoinship with zone(Figure 02) already. As you could see the Figure 03, the area difference would be around 2 sq.m. It's obvious the calculated area of Shop G(Figure 04). However other areas is correct. Any Comments?
Many times once I make a change in the layout, the calculated area in the zone schedule could not immediately display the change. Any Comments?
5 REPLIES 5
Figure 02
Figure 03
Figure 04
Works correctly for me in AC14.
When you placed the Columns or made any change to the Zone, did you use the Update Zone command. Those values will be correct only after the Zones are updated.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Thank you! The update rectify the incorrect area calculation!
