Interactive window schedule ??s
Stress Co_
Can I override a schedule item..... i.e. I want to insert text in place of a window height.
Also, How does one "left justify" text in an interactive schedule? I know how to set the text location in the headers ..... but not in the "body" of the schedule.
Thanks
Marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
11 REPLIES 11
Stress Co_
Never mind question #2....... It's in the schedule settings.
Thanks
Marc
I would use a parameter for the object and list that instead of the height value.
Stress Co_
Nem értem.(I hope that means what I ment)...... but .... what is the "parameter for the object"? The window looks ok in plan and in elevation .... I just don't want to use the dimension.
Köszönöm szépen
Marc
Köszönöm szépen
Marc
Yes, nem értem means I don't understand.
And (just for the others' sake) Köszönöm szépen means Thanks you very much.
Yes, it seems I misunderstood your question. I thought you want to override all values in that column.
Now, the crux of the situation is this: "x CUSTOM" is a text, while 4'-6" is a number, so they cannot be listed in the same column.
See, the HEIGHT column list a parameter of the Window (its B parameter, which is it height). The parameter type of B is a number.
What I can imagine is this. You need to modify the Parameter Script of these affected Windows/Doors for this.
Create a new parameter. Let us call it HeightTxt. This will be a string-type (text) parameter.
It will display the Height of the Door in String format if it is a typical size Door, or it will display "x CUSTOM" if it is custom size.
I did this in the W1 Casement file (I know it's a Window File, but it works the same way with Door files).
See attached image:
I created a new parameter (HeightTxt).
I added the following lines to the Parameter Script:
Status= REQUEST ("Window_door_dimension", "",format_string)
IF tys="Custom Size" THEN
PARAMETERS HeightTxt="x CUSTOM"
ELSE
PARAMETERS HeightTxt=STR(format_string,B)
ENDIF
This will obtain the format string used for displaying Door/Window Dimensions and will set the value of HeightTxt based on the value of B accordeing to the format string.
If the parameter Typ is set to Custom Size, HeightTxt will display "x CUSTOM".
I actually unchecked the hidden status of the Typ parameter so you can access it in the Object Settings Dialog.
Continued...
...continued
Now, In Interactive Schedule Settings, click the Additional Parameters button, and select the Height Text parameter of the Door File for listing And list that instead of the Height value of the Door.
Here is my result in the Interactive Schedule.
I also attach the W1- Casement-2.gsm file that I modified so you can see how I achieved it.
Good Luck!
Stress Co_
Laszlo:
That's félelmetes! (Sorry if that doesn't mean" Awesome")
I think I can make it work.
Thanks for your help.
Marc Corney
Yes, that is awesome (félelmetes). And even your spelling is correct!
You must have some Hungarian friends or other connection. Do you?
I am glad it was not only Hungarian equivalents of 4-letter words that you were taught.
One more thing about the schedule: in the Parameter Script, you can create additional typical sizes for your Doors/Windows if not all you need is available to you currectly.
Learn and get certified!
