Is it possible to schedule a COUNT of zones and not get a list of each zone?
aaron s
cheers
Aaron
AC21
Sure.
As your criteria just search for element type is 'zone'.
As your field just use 'Quantity'.
Make sure you 'Merge Uniform Items' and you will have a count for the total number of zones.
Or are you actually after something else?
Sure.
aaron s
Thanks so much. I had not seen the "Merge Uniform Items" button.
