2022-04-08 06:25 AM
For my projects, there often seems to be items of text that are relevant to all of my projects that I use on all projects. Currently I have a template with all of the bits of text I often used saved in a chart on the ground floor plan tab.
When I require one I simply go to that area and copy/paste into place.
I wondered if there was a more efficient way of doing this, such that I can save them all into my template file and then select the relevant text via a drop down / menu and insert into place.
I do already use labels for things like windows and beams to create schedules. Perhaps there is some functionality I am missing within this area?
2022-04-08 06:59 AM
The Project Info palette (File>Info>Project Info) allows you to add custom fields when can then be used as autotext.
2022-04-08 07:20 AM
You can save them as favorites, I have everything I need to draw an entire structure presaved in my favorites
2022-04-08 11:15 AM
I prefer the Project Info : Autotext method mentioned by @Rico because it is extremely flexible.
The common text can be inserted into any place in Archicad that accepts text - any tool, function, anywhere.
It is a database... if you change the text in the Project Info field - the text is changed everywhere in the project - no need to hunt it down.
(Because of this database-like feature - the Autotext ID pulling in the Project Info field - not only can you correct/adjust the text - but if you need to translate the text, you have only the Project Info to translate and it appears everywhere. E.g., a Canadian architect who has a project in Quebec.)
A negative is the challenge of naming all of these text phrases so you know which Autotext to select.
2022-04-08 01:20 PM
One issue I've encountered is that you can't control linebreaks. This sometimes might lead to a bit botched up text, that you wouldn't have set if it has been done manually.
It's just a minor thing really, but sometimes has to be considered.
This just has let me think of a wish 🤔: The possibility to "render" autotext (make it regular text).
2022-04-08 08:28 PM
I like to use properties for all my auto labels.
I use auto text for constants.
Either way it's all saved to my favorites.
