Is there any way to get .rvt files into ArchiCAD yet?
Gus
Is there any way to get .rvt files into ArchiCAD yet, without owning a copy of Revit? Maybe through a chain of conversions for example?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
2 REPLIES 2
Sort of, via IFC format:
http://helpcenter.graphisoft.com/troubleshooting/import-export/troubleshooting-guide-for-ifc-based-d...
http://helpcenter.graphisoft.com/guides/archicad-19-int-reference-guide/interoperability-2/file-hand...
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
It will never be automatic process. The structure of the model is totally different. For example there are no layers in Revit and There are no Worksets in Archicad.
You can export 3D information via IFC, but it's not all roses as again Revit and Archicad have different tolls for different things. For example no slanted walls in Revit, no parts in Archicad.
You can import 2D data via dwg.
Learn and get certified!
