Keeping linweights
I exported my drawings from Ac to Autocad.
Everthing went fine, except that I lost my lineweight settings, so when I import to Autocad and then print , everything has the same lineweight.
Can the setting for lineweight be saved?
8 REPLIES 8
Try to use "Save as out put" translator , while saving to DWG .
Is that working for you, couse its not here
mm.. i thought it works.. any way check pen translating options?
at least till some one has a good thing to say!! not like me!!
check this any way
http://archicad-talk.graphisoft.com/viewtopic.php?t=614&postdays=0&postorder=asc&highlight=translato...
Could it be because I have Auotocad 2007 and AC 10.
Ism saying this, because translators in AC go up to Autocad 2006.
Could that be a problem?
http://archicad-talk.graphisoft.com/viewtopic.php?t=16548
sorry i don't have Autocad on my computer right now to test
No thats not the problem.
Anyone has a solution?
Done it!
Mario wrote:
Done it!
Happy? share your good moments with us tell us how? what was the problem
Learn and get certified!
