Collaborate forum
LOCATING IT IN ARCHICAD 22
I know how to use and add auto text in AC and the Layout Book. What I am lost on is adding or modifying the list of available auto text, like you can do with project info.
As an example, in placing the autotext System>File Path, I want to modify the string so it doesn't display the name of the person working on the drawing.
Is there a way to modify the preinstalled autotext scripts? If so, please direct me as to where that can be done.
Thank you in advance!
1 REPLY 1
"System/File Path" shows only the file path of the .pln file, not the name of the person working on it.
Are you sure you're not adding also "System/Last saved by"?
