2008-11-03 10:39 AM
2016-05-21 02:44 AM
2016-05-24 09:03 PM
2016-05-27 09:31 PM
laszlonagy wrote:So what is the alternative within ArchiCAD to making this work so labelling 2D documentation is efficient like it should be? Modelling 400+ skirtings in a building with 100 rooms that you need labelled in internal elevation views of the room?
I hope this explanation makes sense.
2016-05-27 10:10 PM
another Moderator
2016-05-27 10:13 PM
strom wrote:I may be misunderstanding your need for scheduling labels vs scheduling the building elements (which store the same data as the label)...
Having to manage MASSIVE slow building models with rooms that model everything like joinery and skirtings so that your Labels will be correct. This is a sure way to loose any documentation profit that was once a profitable phase of architectural services.
If there is a way to show documentation efficiency then this is a great thread for GS to show it is addressing effective ways to label and text the contents of a building WITHOUT having to MODEL EVERYTHING.
2016-05-31 12:58 PM
2016-06-04 11:44 AM
2016-06-04 03:48 PM
another Moderator
2016-06-08 12:03 AM
I have always created my "label" schedules with existing AC toolsSaying this is fine if you document in a particular way to suit the tools however in medium sized to large practices you need to document in a particular way.
2016-06-08 12:26 AM
another Moderator
