Library Ojbects exploding in DWG conversion
Hello All,
Im having this little problem with my library parts when converting it into DWG's. For some reason, my toilets keeps exploding in the dwg file. Its not every toilet, but every other toilet. I've check the translator settings over and over again and cant seem to find what the problem is. My co-workers settings does not explode the toilets, Ive set mine to exactly what his is, but Im still getting the same problem. Does anyone know what is wrong? Do I need to re-install archicad?
Thanks,
1 REPLY 1
Erika Epstein
There are many settings in translators.
Have you tried importing a translator from one of your colleagues?
Did you get the same results?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
