Collaborate forum
Lines on exterior elevation
2raarchitecture
I have tried to change the settings in order to get rid of that rectangle. I know the line at the base represent an elevation line i.e. attic floor level.
8 REPLIES 8
SenecaDesignLLC
If you have overlapping faces you will need to use seo or stop the overlap
FREE wall Accessory framing and coverings
bit.ly/BIMRithmWallAccessories
FREE Truss object.
https://bit.ly/BIMRithmTrussV1
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
Rubia Torres
Hi @2raarchitecture,
I second @SenecaDesignLLC! However, if you haven't solved the issue yet, could you drop here a 3D cut view through these lines?
Rubia Torres
Customer Engagement Trainee | GRAPHISOFT SE
Need help refining your modelling skills?
Check our Design category for the best workflow + tips&tricks!
Rubia, for the project at hand, this was solved, but I saw it showing up at another project. I will be attentive and report back if any trouble. Last, some relatives are last named Torres, so It was a welcome surprise to see your name here! Thank you!
2raarchitecture
Seneca, please, what is SEO in the context of Archicad. I don't know that one. I remember lining things up to solve this. I am also much aware of floor levels to make sure walls are not set to extend a dimension up or down.
Solid element operations.
FREE Truss object.
Hi @2raarchitecture. If you are interested in learning more about SEOs, we have this user manual at hand. And what a nice coincidence you have some Torres folks in your family. My lost cousins 😄
Rubia Torres
Lingwisyer
When you have been working with websites and marketing too much...
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
Win10 | R5 2600 | 16GB | GTX1660
Read my mind! we should double check those acronyms
