2021-11-17 11:34 PM
I have tried to change the settings in order to get rid of that rectangle. I know the line at the base represent an elevation line i.e. attic floor level.
2021-11-18 04:06 PM
If you have overlapping faces you will need to use seo or stop the overlap
2021-11-30 07:17 PM
Hi @2raarchitecture,
I second @SenecaDesignLLC! However, if you haven't solved the issue yet, could you drop here a 3D cut view through these lines?
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
2021-12-11 11:05 PM
Seneca, please, what is SEO in the context of Archicad. I don't know that one. I remember lining things up to solve this. I am also much aware of floor levels to make sure walls are not set to extend a dimension up or down.
2021-12-11 11:06 PM
Rubia, for the project at hand, this was solved, but I saw it showing up at another project. I will be attentive and report back if any trouble. Last, some relatives are last named Torres, so It was a welcome surprise to see your name here! Thank you!
2021-12-12 12:48 AM
Solid element operations.
2021-12-13 02:17 AM
When you have been working with websites and marketing too much...
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2021-12-23 09:47 PM
Hi @2raarchitecture. If you are interested in learning more about SEOs, we have this user manual at hand. And what a nice coincidence you have some Torres folks in your family. My lost cousins 😄
2021-12-28 08:37 PM
Read my mind! we should double check those acronyms
