Link properties to criteria greyed out in teamwork
Hi everybody,
Is it intentional that you can't link properties to criteria when working in Teamwork?
Is there a workaround?
Also I believe I could tie properties to elements individually, but I can't do that anymore.
Is that a change in AC 19?
Cheers
1 REPLY 1
It says what you need to do right there at the bottom of the Dialog.
You will need to move those files to the Embedded library. I guess it is talking about the Property Objects within the default ARCHICAD Library.
