Project data & BIM
List elements with Multiple SEOs (Solid Element operations)
Graphisoft recommended reducing the number of SEO's in my file after an audit.
I use them liberally, but in an effort to cleanup the file, I'd like to see a list of the worst offenders.
Is there a way to create a schedule of all the elements with SEOs, and sort it by number of operations?
Thanks.
4 REPLIES 4
Not that I know of. And no matter how hard I am thinking I cannot come up with a way this could be possible to do.
I was thinking maybe you could schedule the gross and net volume of elements and if there is a difference between the two, maybe figure out which ones participate in SEOs, but I don't know if that would work. Doors, Windows, Openings also reduce the volume of elements, just as Priority Based Connections and Trim to Roof/Shell operation do. That the gross and net volume of an element is not the same does not necessarily mean that the element participates in an SEO.
At this point, I tend to think that you would probably have to write an Add-On using the Archicad API to be able to mine that data out of a project file. And I don't know the API so I don't even know if it would be possible to do there...
jl_lt
Ace
This would be a nice feature to have. Another thing i was thinking the other day is that it would be nice to have a switch to completely turn off the SEO process for computers performance sake.
agroni
don't want to sound negative, but I think it is about time when Graphisoft says "go crazy on the SEO!!! It will not impact performance!!!!
Many have been waiting for this for a long time
The BIMster @ AllesWirdGut
Currently: Archicad 26
User since Archicad 6.5 (2001)
DavorP
+1 On this! Large files can very quickly slip out of control and it takes very long time to find the SEO causing the issue. Makes the QA impossible!
BIM manager
