2006-07-25 10:20 AM
2006-07-25 12:39 PM
2006-07-25 01:10 PM
2006-07-25 02:19 PM
2006-07-25 02:26 PM
Link wrote:
The most important thing is to keep the paths the same on each computer (at least for PC - not sure how different Mac HD names affect library loading in AC10). If ArchiCAD finds the same path on any machine, you won't have to manually locate them.
Link.
2006-07-25 03:05 PM
Joseph wrote:ensure all of your machine hark disks are called the same name (this doesn't affect their "sharing" network name: System Preferences>Sharing), just the hard disk name - usually it's called "Macintosh HD" by default: don't change it.
Any Mac users have a suggestions.
2006-07-25 03:13 PM
~/archiben wrote:So it hasn't changed in ArchiCAD at all then?Joseph wrote:ensure all of your machine hark disks are called the same name (this doesn't affect their "sharing" network name: System Preferences>Sharing), just the hard disk name - usually it's called "Macintosh HD" by default: don't change it.
and if you don't want to do that you'll just have to load them all from the server!![]()
~/archiben
2006-07-25 03:32 PM
Link wrote:that would be nice. i must admit i haven't tested out AC10 in a network environment thoroughly. tom might know more . . .
I thought maybe GS would imoplement some kind of relative path like in the Drawing tool to help with that. Oh well...
2006-07-25 03:35 PM
~/archiben
2006-07-25 03:41 PM
Joseph wrote:look at the file path in your library manager . . .
Is there a way of telling that if the one loaded is on the intended computer?
2006-07-25 04:10 PM
2006-07-25 04:14 PM
Joseph wrote:no - provided all files are looking to that volume for their libraries . . .
Thanks Ben,
If my server is one of my workstations (do not have a dedicated server yet) would that change anything?
2006-07-25 06:00 PM
Thanks Ben,
have you tried 'sharepoints'? it's a small shareware application that taps into OSX's hidden file sharing features and lets you use a normal OSX system/workstation as a file server . . .
http://www.hornware.com/sharepoints/
~/archiben
2006-07-26 09:56 AM
