MEP Default Settings dialog box
When I open the Tool Settings dialog box the Apply button is not avaiable as it appears in the User manuals. I can`t find the Default Settings dialog box for MEP elements. Could someone, please help me?
https://helpcenter.graphisoft.com/user-guide/84552/
1 REPLY 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
The default settings dialog box is what comes up, if you double click on the tool in the toolbox. It works the same way for every tool, including the MEP tools. It is explained in detail here:
https://helpcenter.graphisoft.com/user-guide/65998/
Note that the MEP tools will only appear in the toolbox if you apply the MEP Work Environment.
The picture you are referring to is from a really old version, the dialog has changed since. The apply button has been removed, and now you simply have to click the icon of the object on the left to apply its settings to the default settings on the right. Thanks for bringing our attention to this, we will update this picture.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
