MEP Modeler & its Versions..+ Electrical Symbols?
1. Would like to know, if one has AC14 but the MEP Modeler version 13, by loading the MEP13 object Library will the MEP Objects show up (knowing that they can not be manipulated), so avoiding dots all over the plans?
2. Does it contain Electrical Objects like switches that show on plan as like symbol of $ and on elevations as the true shape?
Thanks,
Joseph
11 REPLIES 11
I've tried loading them into my libraries several different ways. I assume that they would show up in the "Other Objects" folder when using the object tool, but the folder is grayed out. Any other thoughts??
With MEP Modeler these library parts are not shown in the Object Tool but with the several MEP Tool types that are installed with the MEP Modeler.
If you apply the MEP Profile in the Work Environment Dialog, these Tools will appear in your Tool Box.
Then go to the settings Dialog of the Tool (e.g. Duct Tool) and you will see those types of MEP library parts.
