Collaborate forum
MEP Modeler - edit the slope of a piping
alemanda
Hi all!
I recently bought the MEP Modeler.
I tried to draw a pipe for waste water with a slope of 1% and I was able to do it.
The question is: how to change the slope of the whole pipe route I've drawn before in order to match the given exit discharge height?
Is it possible?
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
5 REPLIES 5
I don't know the answer, I have not worked with MEP Modeler enough to know the answer.
Here is an MEP Modeler playlist on YouTube, hopefully one of the clips will contain the answer:
https://www.youtube.com/playlist?list=PL40B6E31580FD53EC
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
alemanda
Thanks Laszlo,
Plan route Editing seems to be very easy.
While I understood how to draw the pipe with a slope, I didn't find the way to change slope of piping at once. Rather it seems that I should change the slope piece by piece ...
Does Anyone else have a suggestion?
I want to say also that the concept behind the MEP modeler would allow archicad to be also a very powerful structural modeler ... smart connection between parts could be extended to structural connection
Win 10 Pro 64bit
www.almadw.it
I have received the info from GRAPHISOFT that after placement, you can edit the sloping of individual elements only, but not the whole network of elements.
alemanda
Thank you Laszlo.
That's a pity.
Hope they will implement such as pipe editing option in the next version.
Win 10 Pro 64bit
www.almadw.it
furtonb
I've just started modelling a small house, this was almost the first issue I encountered - adjusting inclination for multiple elements is much needed. Probably it would be contextual: so the selected elements are affected only, the elevation change should be also indicated as % (or degrees).
odv.hu | actively using: AC25-26 INT | Rhino7-WIP | macOS @ apple silicon / win10 x64
