Make editable an xref’d DWG
We have a DWG file from a client for a site master plan. It has several other DWG files xref‘ed in to
it but it has not been bound before exporting to us. Does anyone know a way to explode the DWG to make the entire file editable?
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
1 REPLY 1
Josh Verran
Not sure if I'm missing the exact point, but you can select an instance of an XREF'd  DWG, right click, explode (maybe it's break not explode).
Just make sure your suspend groups toggle is not enabled.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
LinkedIn | www.creativespace.co.nz | Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
