Measuring the top surface of walls
Hi Guys,
I have a problem with the calcualate option with walls in ArchiCAD:
There is not an area setting which can be used for calculating the top area of the wall. I could use length and multiply by the width (obvious!!) but the multiplication factor always seems to stick with the database component within property object.
Is it possible to make the quantity factor independant to the property object (ie. not set within the database?)
Thanks
0 REPLIES 0
