2004-01-10 12:46 PM
2004-01-11 10:09 AM
Jay wrote:What kind of geometry? Any 2D solids? Where is the origin? What are the units? What are the limits, and the DWG limits?
We have had a lot of problems merging DWG geometry into ArchiCAD. Sometimes it works, but more often than not 10-50% of the geometry is missing. I thought it might be a size issue so I had one of our guys split the DWG into two files, then merge each one separately. Both merges worked, so we rebuilt a single DWG from the two chunks and the single one still wouldn't merge correctly. That tells me that my translator is working correctly, so it has to be some other problem. Bug?
2004-01-12 07:43 AM
Djordje wrote:
A philosophical question - why merging?
2004-01-12 10:25 AM
Jay wrote:If the merging is causing the trouble here, just open the file, and save it as PLN. Then you can merge, copy/paste, whatever.Djordje wrote:In this case it is because we were going to use the geometry for standard details. Since they never change, I decided I would rather just have them in a PLN file -- the native AC format. That way I clean them up once and they are done.
