2019-07-21 05:44 PM
2019-07-22 12:08 AM
2019-07-22 12:14 AM
2019-07-22 12:43 AM
2019-07-22 01:01 AM
2019-07-22 01:14 AM
2019-07-22 01:41 AM
Christophe wrote:Don't forget that BIMx Lab is just a trial for features they hope to incorporate into the existing BIMx / BIMx Pro apps.
About transparency I invite you to use BimX LAB which works even more better about it
https://apps.apple.com/us/app/bimx-lab/id1305827964
https://www.youtube.com/watch?v=C2lXEhsmNU4
2019-07-22 04:40 AM
psimun wrote:If you convert the 3rd party Objects to Morph, you can use the Modify Segments command to reduce the number of polygons.
I sometimes import other 3rd party objects into archicad, but can really bog down the file.
I was hoping to avoid purchasing an additional piece of software for optimization, but this maybe unavoidable.
2019-07-22 05:02 AM
David wrote:Can you explain how to do this please ?
2019-07-23 04:52 AM
Christophe wrote:Select the Morph, then select the Modify Segments command, in the dialog box select Fewer Segments. Check the result in the 3D Window, and use the PolyCount palette to keep track of the number of polygons. Repeat until the Morph is too rough for its purpose in 3D and use the Undo command to go back one step. The resulting Morph can be saved as an Object if desired.
