2022-08-30 12:10 AM
Not sure why model view options go missing - is this a bug?
This has happened to quite a few saved views and I haven't changed any settings within the model view options.
2022-08-30 12:32 AM
So you are saying when you go into the Model View settings, you have a MVO scheme called "02 Construction" ?
2022-08-30 12:34 AM
yep that's right. This is what it looks like:
2022-08-30 12:41 AM
Have you been merging files, hot-linking files or working in team work?
The MVO schemes apparently now are referenced by a hidden ID number and not the name now.
So something has change the ID number of the MVO scheme - but I am not sure what that is.
2022-08-30 12:48 AM
Maybe you imported Layouts through Organizer from another project ?
2022-08-30 01:00 AM
I do have hotlinks in the file and it is a teamwork file... maybe that's why. What is this mysterious ID number?
2022-08-30 01:01 AM
I haven't imported any layouts
2022-08-30 01:06 AM
MVO schemes used to be recognised by the name a few versions ago.
If you changed the name in any way all the MVOs in your views would become 'Missing'.
Now they are recognised by a hidden ID that we can not see.
So if you rename an MVO scheme, the views will not care and will show the new name.
I think it changed in version 23.
I asked about teamwork (Bimcloud) because others seem to be having similar issues.
Here is one such post.
https://community.graphisoft.com/t5/Document-Visualize-forum/Missing-Model-View-Options/td-p/240830
I am not aware of a fix other than re-setting the MVO in the view settings.
But it may go missing again.
