2020-05-04 02:35 PM
2020-05-05 06:16 AM
2020-05-06 02:17 PM
2020-05-07 03:58 AM
Bruce wrote:On the contrary ! Linking a shared file which is a module is perfectly possible and this solves all problems of linking and updating. The path to an unshared module cannot be ensured if it is not in the BIMCloud. For example, storing a module on a dropbox (or other cloud) does not solve this problem because the access path includes the designation of the hard disk which changes for each participant. THE best solution is to share the modules in the BIMCloud.
linking to the BIM server won't help in this situation
2020-05-07 03:04 PM
2020-05-07 04:27 PM
2020-05-08 05:02 AM
2020-05-08 05:40 AM
2020-05-08 06:01 AM
LaszloNagy wrote:I've read...
Christophe, I think we are talking about different things. You re talking about Roles in BIMcloud, I am talking about ARCHICAD capabilities.
Bruce wrote:We can read that Bruce is not used to use remote project or sharing a project. I have read by "How...publish modules to the BIM Server?" that means Bruce need to send a module to BIMCloud. So that he need to check his BIMcloud role.
How do I set up my publisher to publish modules to the BIM Server? It's not an available option that I can see.
2020-05-09 11:42 AM
2020-05-09 05:58 PM
2020-05-10 10:44 AM
2020-05-11 07:32 AM
2020-05-11 07:35 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-05-14 12:15 AM
Minh Nguyen
GRAPHISOFT
2020-05-14 12:44 AM
2020-05-15 12:31 AM
Minh Nguyen
GRAPHISOFT
2020-05-15 06:27 PM
2020-05-18 04:58 AM
Minh Nguyen
GRAPHISOFT
2020-05-18 02:21 PM
