Collaborate forum
Modelport 2 model cut by cut plane in floor plan
Does anyone know how to get a Modelport object cut by the cut plane of the floor plan?
Imported a large 3d scanned interior model and all looks good and fast, except that
Hello Atlant Pashko,
Open your gsm object
Delete all 2D script tab and write this script into 2D script tab (https://gdl.graphisoft.com/reference-guide/binary-2d) :
FRAGMENT2 1,1
Draw what you want or need into the "2D symbol" tab
Your draw will be your 2D object plan view
Or you modify 2D script too like this :
IF var THEN
FRAGMENT2 1,1
ELSE
"Here the original 2D script"
ENDIF
By this way you have to create a new parameter which is called "var" to be able to choose between the original 2D view and your own 2D symbol.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 26 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2015 - 16Go RAM
FRAGMENT2 1,1
IF var THEN
FRAGMENT2 1,1
ELSE
ENDIF
Thanks Christophe,
Replacing the drawings in the 2D symbol worked and is the best solution so far. Of course it would be better if it could be cut by the cut plane, and change the 2D drawing accordingly
About this there is the COMMAND which is called CUTPLANE :
http://www.selfgdl.com/3d_elemente/schnittbefehle/a_CUTPLANE/kompendium.php
For example about 3D script:
	ADDZ lowcut/100
	CUTPLANE 1, 1, 0, 1
	DEL 1
	ADDZ highcut/100
	CUTPLANE 1, 1, 0, 0
	DEL 1
	CALL name PARAMETERS
	CUTEND
	CUTEND
highcut and lowcut are 2 parameters you have to define before
/100 because I prefer working with centimeter
Christophe - FRANCE
