Most recent version of AutoCad that ArchiCAD can import?
R Muller
Which AutoCAD dwg versions can I import into archicad 19 and/or AC18? 2013, 2014, 2015, 2016? Where is this documented when a new release of ArchiCAD comes out?
R Muller
AC 26 USA (20+ years on ArchiCAD)
MBP 64GB Apple M1 Max OS 12.1 Monterey
4 REPLIES 4
In the DXF/DWG Translation Setup Dialog, in its Save Options page, you can see in the File Format field the AutoCAD versions supported. The latest is AutoCAD 2013.
However, what you need to know and is also visible in the field, that the file format changes every 3 versions. So, for example, AutoCAD 2014 and 2015 also use the same format as AutoCAD 2013.
So the answer to your question is that ARCHICAD should be able to open DWG files of version up to AutoCAD 2015.
Erwin Edel
As a workaround I have AutoDESK Trueview installed (free DWG viewer). This can save back DWG to older version.
It's also handy to proof-read DWG I send out
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
R Muller
Thank you for your very informative answers.
R Muller
See some more info and a definite answer about this:
http://archicad-talk.graphisoft.com/viewtopic.php?p=248867#248867
