christopherwilliams wrote:
I don't want to have to save it to a pdf and then open the pdf in photoshop and export a jpg from there?
Please edit your forum profile to add a signature listing, at a minimum, your operating system and the version of ARCHICAD that you are using.... or include that in any posts.
There is no control over pixel dimensions when saving in an image format - only compression. At least on MacOS.
PDF export and conversion is the only way I know of to get a desired pixel size result. if you use a Mac, then it is all built in - no need to purchase other software. You can publish everything to PDF and then open that in Preview. Or, you can Print a layout (vs Save) and click the PDF options in the lower left of the print dialog to open a PDF in Preview... a hidden/local copy of a PDF will open. From there, File > Export to JPEG and choose the desired DPI and compression for the resulting JPEG.
Out of curiosity, why do you need a high pixel dimension JPEG vs a PDF?
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
