No cut fill in objects imported from Autodesk Inventor
gdford
When i import objects from autodesk inventor they have no cut-fill. I find no way to control this via a translator. I can open one of these objects and modify the GDL and get a cut-fill, but there are thousands objects and they are a moving target during design.
Does anyone know anything about this.
Below is a dropbox link to the inventor file...
I have been using Merge to import into archicad 23 - it takes awhile.
https://www.dropbox.com/s/w3zbzqrfwkvy5a2/ACAD_SOLID%20TO%20SURFACE%20TESTdwg.dwg?dl=0
Thanks
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
0 REPLIES 0
