Hi to all,
I have a problem.
I need to export to dwg and the dwg produced by archicad misses all the texts coming from the label "object 13" with custom type (see the attached picture)...
The only way to get the correct result is to produce a dwg with the drawings as blocks in the paper space. But I need drawings in paper space as cut views ...
I use AC13 build 3600 64bit on windows vista business.
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
