Opening DWF files in archicad
I have been recently working with archicad after having worked with Autocad.
Therefore I have many dwf files created in Autocad that I wish to open in Archicad. Is this possible? I tried to open one and it shows as being blank.
If someone could help me I would be very grateful.
Thank you.
12 REPLIES 12
and now all these years later, im stuck with the same problem with the DWF.
im trying to download details from Sweets and get the same box when i plac eit into AC.
any solutions yet....im on AC 11.
My colleague is trying to open 3d DWF shop drawing files from steel fabricator to check against our model.
In AC11 we try File> File Special> Merge and select the file - nothing happens.
In AC15 using File> File Special> Merge we get the error message below.
Any suggestions please? They have suggested we download Design Review from Autodesk, but that hasn't worked either - not Mac compatible.
And years later we still have this problem. Trying to open a DWF with Archicad 26 and I get the same error message. 6.2 not supported... 😞
