Collaborate forum
Opening DWG from AutoCad 2009
I have ArchiCad 10
When I try to open a DWG file from version 2009 I get a File Open Error "The file you are trying to open is damaged. Do you want ArchiCAD to try recovering it?" When I click "Recover it" nothing comes up.
Since I can open other versions of AutoCAD, I have a feeling the problem is in AC10 not being able to handle AutoCAD v2009. Is there a fix?
Thanks,
Michael
3 REPLIES 3
Gerald Hoffman
I am not positive but since AC 10 came out quite a long time before 2009 I suspect you will not be able to open it. You will have to save the ACAD file back to version 2007 or so and then it should open fine.
Cheers
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
That was the problem. V2007 opens OK.
Thanks Gerald
There has also been several mentions of free DWG converters. You can search for them on the forum, or here is one post about it from Djordje:
http://archicad-talk.graphisoft.com/viewtopic.php?p=108924&highlight=dwg+free+converter#108924
If you don't have access to the person who sent you the AutoCAD 2009 file, then you can use that DWG converter to create a earlier version file.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Labels
