Opening a Revit drawing in Archicad 21
mukster
I am trying to open a .dwg Revit file in Archicad 21. Some of the drawing is there, but other parts are missing.
Does anyone have any ideas?
Working on a Mac platform
5 REPLIES 5
Dwg is not a revit file dut an Autodesk file
There is no BIM consideration into a dwg
First of all what about the dwg translator export since the Autodesk software?
Is it only drawing ? or drawing with layout ?
Which dwg translator did you use with AC21 ?
What are the things you think you lost when opening this dwg file?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Carstenem
If possible try to get an ifc export from Revit, then you can open the ifc file in ARCHICAD.
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Good Idea to get the 3D model
But IFC don't have any 2D inside with the exception of some minor graphic information
Christophe - FRANCE
rvtuser
Is this the reason why REVIT shows everything as generic or not real when importing a IFC File? You can see the Floor Plan and 3D Model in REVIT, but everything is imported as a rebar material...any help?
Check your IFC import settings for how it translates materials. It can be set to make everything an existing uniform material, or create a new material for each imported one.
Ling.
ps. This thread should be under the Collaborate sub...
