2019-06-20 07:53 PM - last edited on 2022-09-30 03:48 PM by Oleksandra Vakariuk
2019-06-21 10:29 AM
2019-06-21 12:47 PM
2019-06-21 12:57 PM
Carstenem wrote:Good Idea to get the 3D model
try to get an ifc export from Revit, then you can open the ifc file in ARCHICAD.
2021-09-03 09:40 PM
Is this the reason why REVIT shows everything as generic or not real when importing a IFC File? You can see the Floor Plan and 3D Model in REVIT, but everything is imported as a rebar material...any help?
2021-09-06 03:35 AM - edited 2021-09-06 03:35 AM
@rvtuser wrote:everything is imported as a rebar material...any help?
Check your IFC import settings for how it translates materials. It can be set to make everything an existing uniform material, or create a new material for each imported one.
Ling.
ps. This thread should be under the Collaborate sub...
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
