2009-09-03 08:21 AM
2009-09-03 10:31 AM
mdjohnson11 wrote:If you placed a pair of doors, and mulled (ganged) them together, then yes, two doors would appear in the schedule.
Is there a simple way for door schedule to read a pair of 2'-6" doors instead of 5'-0". I assume the height and width in the schedule is reading the opening instead of the individual panels.
2010-05-14 08:16 AM
2010-05-14 08:49 PM
ksymons19 wrote:Back online after a week away....
I saw Karl's post and tried ganging the doors and I have two issues - a) it still separated the two doors on my schedule and did not appear as PR 2'-6"; am I missing something? and b) how do I get the ganging to NOT show framing at the center?
Thanks!
2010-05-15 04:45 PM
2010-05-15 09:10 PM
Matthew wrote:But, the 'user defined' parameters result in a different column in the schedule and there is no way to automatically copy the measured width into a 'user defined' for all objects except the one with the pairs. Similarly, if the user typed in PR 2'-6" in a user-defined field, it would appear in that column only for that one door - but the total width would still appear in the width column.
I've done this with custom doors for a client. The only way I can see to do it with the standard doors would be with the user defined "parameters for listing" or the door IDs. These could be set fairly quickly with the Scheduler and maintained with favorites. It's definitely asemi-automatic approach but not too bad if you don't have to train too many people to do it.
2010-05-16 06:57 PM
Karl wrote:I didn't say it was ideal (or even good - note that I have only done this within a custom library for one particular client). One would have to use the same approach for all the doors. The parameters (or IDs) can be set and managed in the scheduler.Matthew wrote:But, the 'user defined' parameters result in a different column in the schedule and there is no way to automatically copy the measured width into a 'user defined' for all objects except the one with the pairs. Similarly, if the user typed in PR 2'-6" in a user-defined field, it would appear in that column only for that one door - but the total width would still appear in the width column.
2010-05-16 07:21 PM
