Collaborate forum
Placing schedules on layouts in AC25 - why is the formatting missing?
amgam
See attached screenshot - Archicad used to enable to "split" bigger schedules into rows to fit in the layout. Now this functionality is gone.
Can anyone point me to a solution here please?
ArchiCAD 25 FRA 3011 + TwinMotion 2021.1.4
iMac Retina 27 2020 3,8 GHz Intel Core i7 8 cœurs
64 Go 2667 MHz DDR4
AMD Radeon Pro 5700 XT 16 Go
6 REPLIES 6
I just opened a legacy project in AC25 to test this... and my wrapped schedule strangely showed up on the layout as unwrapped.  But, the wrapping option did show up in the pet palette and worked fine to wrap it back to how it was supposed to be.   Are you clicking on the bottom right hotspot?
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
That may be because those schedules do actually fit on your page.
I can't tell from your image but it looks to me as if the schedules will fit.
I am pretty sure the split option is only available when the schedule is longer/wider than your page.
Versions 6.5 to 25
Francois_MCD
Hi @amgam
What version of Archicad 25 are you working on? Is it the official version (from Graphisoft official website) or perhaps a version downloaded from an external / 3rd party website?
While helping local clients with "Archicad issues", I came across several that had the same & very similar issues like you mention here. They all turned out to have used an installation file from a 3rd party website.
Did you try to re-download & re-install Archicad 25 from scratch? Perhaps also try to do a Preferences Cleaning - https://community.graphisoft.com/t5/Project-Management-articles/Preferences-Cleaning/ta-p/303676
I hope this helps, let us know how that goes.
Regards
Francois Swanepoel
Hiking, Motorbiking, Good food, Gr8! Beer & excellent conversation 😉
www.fusionBIM.co.za - Architecture - BIM Implementation - ArchiCAD Training
www.Scirrus.co - LiDAR Digital Survey - Scan2BIM As-Built - Property Compliance
www.BIM2fusedVR.com - Virtual Reality Capture, Render Studio & Matterport Service Partner
vistasp
The option disappears if the frame is set to "Crop Frame to Drawing". It should reappear if you change that to Fit Frame to Drawing or Manual Resize.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-26 INT | Win10 | Ryzen 5700 | 32 GB | RTX 3050 |
I think the OP is talking about adjusting the frame, rather than "splitting" it to multiple sheets, Barry (although that was the word used to describe the issue).
= v i s t a s p =
bT Square Peg
Yes! Solved. Thank you, I never knew about these options. I'll update the first post so that people have no trouble finding the solution. Thanks a lot!
64 Go 2667 MHz DDR4
