2006-06-07 03:50 AM
2006-06-07 05:05 AM
2006-06-07 05:05 AM
2006-06-07 05:14 AM
2006-06-07 05:20 AM
2006-06-07 06:26 AM
2006-06-07 06:40 AM
2006-06-07 06:40 AM
2006-06-07 06:55 AM
2006-06-07 07:16 AM
2006-06-07 09:14 AM
Pitulon wrote:I agree with you 100%.
thx guyz for replying on this one.
Well, i NEVER said that the PDF is NOT vectorial, but i said is NOT for further vectorial editing from a previous vectorial program. The vector conversion language of PDF is very BAD (or exact, or whatever) If u publish/print your drawing in PDF and try to reconvert it back to AC, you will loose on 1 meter, 1 milimeter so 1000 mm will become 999mm...it looses accuracy over these conversions, and not mentioning the curvers translated into line segments and exploding everything, even TEXT, into ONLY lines, and always distroing the drawing, so when imported as DWG or whatever it will look very BAD.
Anyway, my complaint was over the CorelDRAW language with ArchiCAD.
The EPS was the ONLY solution to export a AC9 drawing from PM9 into Corel with almost ALL features UNTOUCHED (fills, line weight, DRAWING SCALE (VEEERY IMPORTANT), curves, text)
Thanx for replying!
Lets add this EPS conversion back to AC10!!! and add it to WHISH LIST!
Cheers.
2006-06-13 08:39 AM
2006-06-13 08:45 AM
Eniko wrote:Nice
I added your request to the ArchiCAD Wishlist database.
Regards,
Eniko Pauko
Technical Support Engineer
2006-06-13 08:47 AM
