SOLVED!
Point Cloud in Archicad
Hello All,
I am new to this forum, first time i am using Archicad with Point Cloud.I have facing trouble at some place. I have set stories (levels) according to point cloud. point cloud visible on the Ground story (Level1 Ground). But point cloud is not visible on reaming stories. Please help me to sort it out. #Archicad #scantobim #bim #pointcloud
Thanks in advance
BwPC
1 ACCEPTED SOLUTION
Solution
The generated GDL Object is by default set to be displayed only on its Home Story.
After the GDL Object is generated and placed from the Point Cloud, select it and go to its Settings Dialog.
In the "Floor Plan and Section" panel, check the "Show on Stories" field. Change its value from "Home Story Only" to the one best serving your purpose, e.g. "All Relevant Stories".
2 REPLIES 2
Solution
Thanks a lot, it's worked
Learn and get certified!
