Project data & BIM
Possible to pair one BIMCloud Basic Manager with serveral BIMCloud Server Module
SeRohde
Hi at all,
since AC23 is released i am about to roll it out in our Company. My Ressources are rather limited at the moment and i seem to not fully understand the possibilities of the new way BIMCloud (Basic) offers.
Basically the question is: Is it possible to pair one BIMCloud Basic Manager with serveral BIMCloud Server Modules (and different Version like v21 v22 v23)? Or do I have to maintain a Manager Module for each of them?
Thanks in advance for any hints, help and suggestions.
Here is our Setup:
http://www.planungs-ring.de/chart/BIM-Chart2.jpg
Admin of BIM [Cloud] [SaaS] [Server] | AC 19-25 [Win&Mac Clients] | VM's
Support for multiple ARCHICAD versions is available only in BIMcloud (but not in BIMcloud Basic):
https://helpcenter.graphisoft.com/user-guide/83069/
Is it possible to update the BIMCloud Basic from one supported version to another or a new intall is required?
We are also upgrading our workstations from 22 to 23 and I see no option in the Manager.
Thank you.
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
Noemi Balogh
Hi uisanata,
It is not possible to migrate a BIMcloud Basic to one version from another. Once you locked it to a certain version, it stays like this (except if you upgrade to full BIMcloud).
In your case, a new installation is needed and projects should be migrated either manually (re-share PLN-s to the new setup with ARCHICAD 23) or through the Migrate Teamwork option (similar to the first, maybe a bit more complex, so I suggest the first option).
Kind regards,
Noémi Balogh
Community Expert, Admin
