Problems with Cadimage StairBuilder 13
hi, I´ve got a problem using Stairbuilder from Cadimage for AC13. After build a stair and put some railings I receive this error message: "file not found at line 250 in the 3D script of file CT railing.gsm", and I cannot see the 3D render window.
Any ideas ? Thanks
I made a mistake in the error name, the correct error is as follows:
"Number of processor cores : 4
Fill not found
at line 250 in the 3D script of file CT Railing.gsm."
Sorry
David Maudlin
Pendu:
See this thread:
Library Parts Not Working Properly
You need to find the parameter that has "MISSING" for a fill.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
