Property Manager_create new properties
[list=]I would like to create a new property group listing the name of occupants and the rooms they occupy.
[list=]I have created the group named coordination --> inside this I will have the new property called occupants.
  • HOW DO I ASSIGN A PERSON TO A ROOM? Please....
  • 11 REPLIES 11
    Would also like to add a 2nd Property:
    Air Conditioning to be added (IF room is a kitchen or a Bedroom)
    Thanks ....
    I know so much as this one is an IF formula but, I cant seem to add the logic for the rooms...so air con is added only to 2 rooms
  • Set the Data Type of the Property to "Option set", define the Option Set values (e.g. the names of persons) and if you want to be able to assign more than one person to a room, then check the "Allow multiple choices" checkbox in the "Options Setup" Dialog.
    Thanks ....
    Could you explain this in a bit more detail?
    Maybe a screenshot and a detailed explanation, like the value of X should be Aif this and this condition is met otherwise its value should be B.
    To better explain :
    I want to have Air conditioning in 3 rooms (3 zones). Bedroom / kitchen / Living room
    So the property created is Air Conditioning (as part of the coordination group). Air Con is to be added IF in either of the above zones.
    Laszlo :
    Regarding Occupants - the Option set list is set up - but how do i then assign a room to each person ?
    Something like this?
    IF ( {Property:Zone/Zone Name} <> "Bedroom", IF ( {Property:Zone/Zone Name} <> "Kitchen", IF ( {Property:Zone/Zone Name} <> "Living Room", FALSE, TRUE ), TRUE ), TRUE )
    Here is the clarification for the Air Con.
    ? 3 rooms/ zones to have Air Con basically.
    atfonit wrote:
    Laszlo :
    You cannot assign a Zone to a Property available for a Person because Person is not an element type in Archicad.
    You can only assign a Person to a Property available for a Zone element.
    Juat pasted the code : ? i have a read error.
