Collaborate forum
Publish to Sketchup
vfrontiers
Is there any way to use PUBLISHER to export SKETCHUP FILES?
Can't seem to find that as an option when publishing a saved 3d view...
Duane
Visual Frontiers
AC25 :|: AC26 :|: Enscape3.4:|:TwinMotion
DellXPS 4.7ghz i7:|: 8gb GPU 1070ti
Nuge
Just wondering if you found a way to publish Sketchup files, I have recently started using Modelo and it would be great to be able to publish sketchup files.
AC25 i9 11900K / 128G ram / GTX 3090 / Enscape
Not from Publisher that I am aware of.
Needs to be 'Saved As' SKP from the 3D window is the only way I know of.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
The attached screenshot shows the file formats that Publisher can batch "save".
While SKP is not listed, IFC is ... and SkektchUp is capable of importing IFC files, potentially requiring a 3rd party add-on depending on which release of SketchUp you are using.
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
