2003-11-18 08:16 PM
2003-12-04 08:05 PM
gobel wrote:Be sure that your PM install has all of the required translation .DLLs and other required AC shared files.
when i want to publish to dwg it doesn't work, cause the only option that i can publish with is postscript or any other image extension... can someone help and tell me where did i go wrong?
Gobel
2003-12-18 08:18 PM
2003-12-19 05:56 AM
michael wrote:File/Publisher/Publish
I have the same problem. The archicad guide Vol 2 states you can save layouts in PM as DWG but I can find no option to do this when I select "saveas" other than the native layout format. What am I doing wrong? I am running AC version 8.1 and PM 3.1.
2003-12-27 09:11 PM
gobel wrote:See this topic discussed in the "Construction Documentation" section under "Plotmaker" I raised the same question and got the answers there. basically you need to go to the publisher Dialoge box and dig a little deeper into the options buttons. You will see a screen shot of the Dialoge box in the section mentioned above.
I have a problem in exchanging from PM to DWG.
my files are imported to PM as pmk not direct from AC file..
Gobel
2003-12-28 09:20 PM
2004-07-07 02:05 PM
2005-01-13 08:35 AM
Djordje wrote:Djordje, I have tried your same instructions using AC9, but when I open the newly written .dwg file, it opens empty! However, it's listed attributes, by the file size show it to be normal. I have tried using the default translator and also a translator that uses xrefs. Neither yeilds a file that I can successfully open with anything 'seen'. Any ideas?michael wrote:File/Publisher/Publish
Drag the layout book to the right window. Name the set, choose the folder you are saving to. Set the file format to DWG (by default it is DWF). Set the translation properties in the Translator.
That's it.
HTH,
2005-01-13 09:02 AM
TDabney wrote:There is an option in the translator to crop the layout to only that seen.
Hi -
When I publish the layout to a DWG, the entire - unadjusted view frame - section view is published. Tom
2005-01-13 03:18 PM
Patrick wrote:I was experiencing the same thing yesterday, but when I took the file to our only PC with AC2000 the file opened fine. Not sure what the issue is when reimporting DWG's that had just been published with plotmaker.
2005-01-14 05:55 AM
Patrick wrote:it's not empty!
