Hello, Is it possible to rotate the NCS Wall Label when it only has a leader line (not a pointer line) in section and plan views? I can't seem to rotate it. It's only orientation is "up" with the leader line below it. It looks like it's possible to add a pointer line and reformat the label each time to the desired orientation, but it would be quicker to keep it as a leader and just change it's rotation.
Thanks,
Reid
ArchiCAD 24, 25 & 26 US
WINDOWS PC, 16GB RAM, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3.40 GHZ, NVIDIA GEForce GTX 970, ASUS, CM6870, Rev X.0x
