Quick method to modify mulitple Layer Combos at once
Josh Verran
Is there any way to quickly turn new layers on and unlock for existing layer combos, rather than having to manually turn the eye and lock on next to each layer combo name?
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
LinkedIn | www.creativespace.co.nz | Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
sinceV6
Hi.
You can use the Attribute Manager to change several layer combos at once.
Best regards
1 REPLY 1
sinceV6
Hi.
Best regards
