2022-10-04 01:04 PM
Hello, everyone. I'm new to Archicad and I'm finding it difficult to represent my model properly on 2D plan. I happens that the railings of the stairs is not showing up on the slab. I want to show this railings U-turn, adjacent to the slab. Not just that, but those stairs notes and symbols "descend", "ascend" the slab is cutting out. Don't know why.
Solved! Go to Solution.
2022-10-04 03:52 PM
yes, this has been an issue. the program cannot show the bottom part of the rail be underneath the slab, whist the top rail be above it. the Send to Back/Front works by element, & a single rail modelled like yours is considered a single element.
the way we've been working around this is to split the railing & have the bottom rail stop at the landing, show it one story up, & bring it behind the slab. the top rail starts from the landing & finish at the top of the flight & obviously above the stair / slab.
with the new slab display capabilities (ie. auto-detect columns/beams/other slabs) & have it show either dashed or solid lines depending if it is above or below the columns/beams/other slabs, perhaps the railing tool will be added to this feature too.
2022-10-04 07:01 PM - edited 2022-10-04 07:13 PM
Might you be able to use the stairs Floor Plan settings? Set a custom breakpoint then set your stories above to hide below the breakmark.
Ling.
Edit: This does not seem to work properly... the section of the railing not associated with the stair shows hidden instead of continuing from the stair setting.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2022-10-06 10:51 AM
Ahhh... Has this problem been reported to Graphisoft? I wonder what would cause this to persist until version 26. It is unfortunate.
Thanks for the response, folks! God bless!
